power steering problem
i was the steering felt fine, when i went to drive again like 5 min later when i first left i had no power steering, before i could get out of the parking lot it was back to normal, drove fine all the way home, i shut it off and turned it back on and the steering was back to crap. i check the fluid and it is a little low. i didnt drive all day then this morning i started the car and drove it around the block a couple times and the steering is fine now. i never added any fluid or anything. could it be the pump? how much do they cost and are they hard to put in? can i get some directions or something. thanks for the help
If the steering just locks up for a little bit ,then goes back to normal,then it's the rack itself.Get a rebuilt one ,besure it has a one year parts and labor warranty,as my rebuilt went out 8 months later with leaking fluid and everything.(Look under the car for wet rack).Mine used to lock up on cold mornings.Hope this helps.
one of my Z's did that once at mcdonalds! the PS just totally stopped working so i parked it, pulled the cap off the reservoir and it was like pressurized when i unscrewed it. after i relieved the pressure i started it back up and everything was fine forever after that. no leaky rack or anything. i know on both my cars the lid seems to leak on the PS reservoir but yet it is never low, it almost looks like it's too full if anything. i'm not sure what the deal is.
IMO get a used, low milage one out of a junkyard (what I did) or get a reman one from GM. Don't bother with part store crap.
stockssn2o
05-25-2015 08:54 AM
SMO Q
02-11-2015 07:13 AM
