Power Steering Pulley Removal
It's a major PITA to remove the pulley...and you have to have a special tool to do it with also...it's a pressed on pulley
Just take out the two 10mm bolts holding the pump on the bracket and that should give you enough room...if not just disconnect the two lines going to it and you'll have the whole thing out of the way...
stockssn2o
05-25-2015 08:54 AM
SMO Q
02-11-2015 07:13 AM
