Power Window Switch
Power Window Switch
My power window switch for the drivers side window on the drivers side will only let me roll it down. when i try to move it up and press up on the switch it doenst move up, sonmetimes it works sometimes it doesnt. it has to be just right to roll it up!. it is messed up, like the switch moves up and down freely like there is no switch. but the passenger switch is fine. the drives side switch just seems loose. so i think its broken. i plan on buying a new switch but am wondering how to replace it. i took the trim piece and pulled it out a little bit and there are only a bunch of wires going to it, where is the harness end to unplug? or what do i do? do i have to buy the whole trim or just the two switches together. thanks help me out!
are you sure abou tthat because i think i read that shoebox said that you can just buy ths power window switches by itself, withought the power mirror and door lock switch. i think also said they come out separately i jsut didnt see the plug where to unplug just the window switches.
ok, how much was that whole switch and how hard was it to fix. do i have to take my door panel off to get to the hareness to unplug from under the dash? im kind of confused. did it fix your problem? was your problem like mine, one of your switches felt really loose and when you pressed up or down it didnt work?
Oh! wow thats a lot of money!! i plan to do it myself so i just need thw switch or piece that you have but if SHOEBOX is out there id like for him to see if i can just get the switch because i think i read a post that he said you can just buy the switch which is both the passenger and driver because it is together! thanks man!
I am not sure what year your car is and how they are different, but mine is a '94 and I replaced mine last year, drove up to the local dealership and they had one in stock. It was just the switch portion and cost me around $15.00 and took me all of 2 minutes to install...did it in the parking lot of the dealership with no tools. Just pop out the trim panel, un hook the harness, whole assembly with wires will unhook from all switches at once. Pop out the defective switch and pop in the new one.
Good Luck
Aaron
Good Luck
Aaron
1 - The switch is sold by itself without the whole trim panel and harness.
2 - If you manage to get the whole door panel trim assembly off which takes me about as long as it takes to scratch your *** a couple times, you should see the harnesses for the mirrors, locks, and windows (at least on the T/A it is) and they simply unplug.
ok guys thats what i was hoping for that i could just buy the switch to replace. i have a 95 z28 so it should just be like yours. but heres my question when you said trim panel, did you mean the whole door panel, or just the little oval trim piece that has the mirror control, door lock switch and the power window switches. i took the small oval trim piece out and i couldnt find a way to unhook the switches because the wires went into the door somewhere im not sure.
Just the little panel with the switches in it....should just unsnap from the door panel
Oh ok thanks guys. i think the end of the harness is stuck in the door somewhere so thats why i didnt see it, im going to tug and pull on it a little bit to get to the end of the harness but how do i get the switches out they seem like they are stuck to the oval trim piece pretty tite, do i push or pull on them?
