Preparing to Fix Intake Gasket
I've seen some post recommending different types of RTV/sealants. Could anyone tell me which is the best to use? Also is it better to order the gasket from GM or an aftermarket supplier?
Brian
Brian
Re: Preparing to Fix Intake Gasket
GM and Fel-Pro are about the most common sets that are use the most. GM will supply it's own RTV sealant with the kit, I don't know if fel-pro does? The key is to lay a good bead on a clean surface.
10-31-2016 11:09 AM
