Problem with Brent's SKIP SHIFt mod, no GRAY WIRE!
I'm in the middle of doing Brent's mod to disable skip shift and I've run into a bit of a problem. There is no gray wire in slot 13, or any wire in slot 13 for that matter. I successfully removed the white wire but there is no gray wire at all. What should I do now? Thanks!
Originally posted by dak125
http://www.bfranker.badz28.com/96SS/skipshift.htm
There's nothing in slot 13.
07-04-2005 05:00 PM
