problem....for instance, put ur car in 6th gear going 20 mph...resembles
whats happening, i just did header install, and in most gears below 2k rpms , after header install, and im runing open headers, it jerks and omg the gear shifter feels like it did b4 i changed my driveshaft from the stock one to the aluminum one (the over 80 mph problem) and it was bad enuf to where i thought i didnt bolt the motor moutns back up, but i checked them and they looked tight to me...didnt jack the motor up or anything but the nuts and bolts felt snug, ...is this normal for the shifter to actualy be jerking hard after a jet hot longtube install? open headers...any help is aprecaited --thanks alot
I bet it's a burnt plug. Mine was shaking like crazy, found a burnt plug. Ran alot better but still shaking a bit in 6th in low rpm's. Looked again the next day and found the other burnt plug. I'm thinking you should also get a lt4 k.m. Just keep on looking, you'll find the problem.
Originally posted by glennxx1
johny, was ur shifter shaking?
ChrisFrez
12-07-2014 06:01 PM
07-04-2005 05:00 PM
