Project LT1 503 cam
Old 03-23-2008, 11:13 PM
  #16
mdacton's Avatar
Originally Posted by dangalla
and im still waiting for a vid of your car
Just make it to the EFA shootout, see it in person......you may be dissapointed
mdacton is offline
Old 03-23-2008, 11:45 PM
  #17
Verz's Avatar
Sounds so familiar. Bought mine for 2k, full suspension, ewp, crane 1.6rrs and catback but has a blown motor. So i decided to go the "cam only" route using a 503. Previous best was a 13.4@105.
Good work and keep us updated.
Verz is offline
Old 03-24-2008, 01:38 AM
  #18
MeanGreen97Z's Avatar
How did it run?
MeanGreen97Z is offline
Old 03-25-2008, 07:40 AM
  #19
mdacton's Avatar
Originally Posted by MeanGreen97Z
How did it run?
have not run it yet, this sat. but they are calling for rain
mdacton is offline
Old 03-29-2008, 03:14 PM
  #20
mdacton's Avatar
How did it run?
Well we ran it this morning.....track was crappy, and we ran it on a stock tune.
12.55 @ 110.7 8.01@ 89 in the 660
Not bad but we lost 60' so If we can get that back we should go faster.
Exaust is really choking it, needs longtubes,gears and a bigger converter. I think it will go 11's cam only. Not so sure if a tune will pick it up any or not.....
Either way it has some more in it
mdacton is offline
Old 03-29-2008, 03:29 PM
  #21
Dave1980's Avatar
Hey thats my old cam! Good t see you put it to use.
Dave1980 is offline
Old 03-29-2008, 03:33 PM
  #22
mdacton's Avatar
Well...I see its still good
mdacton is offline
Old 03-29-2008, 07:40 PM
  #23
mdacton's Avatar
Going to try it out again tommorow, The track tom. always runs faster
mdacton is offline
Old 03-29-2008, 08:56 PM
  #24
Shon Herron's Avatar
:I just read the first post:
The car can go LOW 12s and upper 11s if you work on it.
I put the HOT cam into the upper 11's
:read some more:
I can send you a tune to upload just to try, have had good luck with it locally :-)
Are you running an A3 or A4? Probably going to need a 3500ish GOOD TC and of course, the lower weight the better.
Shon Herron is offline
Old 03-29-2008, 10:56 PM
  #25
Kaj
Kaj's Avatar
I figured you'd be in mid 12's. Props man, a better TC, Lt's and perhaps a dumped TD exhaust, weight reduction w/ tune you're in the high 11's low 12's
Kaj is offline
Noenav
03-01-2019 07:38 AM
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
BIGCOWL-IMP
11-21-2014 09:40 AM
Quick Reply: Project LT1 503 cam
