Project Update: 355 LE2 Head / LE3 Cam is in, running, and on the road...
#17
Re: Project Update: 355 LE2 Head / LE3 Cam is in, running, and on the road...
on the header leak:
I found it easier to just have that welded up. You have to take the steering shaft out but that's EASY and no more leaks.
#18
I've been taking out my steering shaft everytime anyways.. didn't know all that. Might just have that done, even tho they're coated I'll just sand off some of the coating, I don't care anymore about how pretty it is
#19
I swore off Hooker LTs b/c of that slip fit but got these in a "deal" so I welded them up and all is well. but the flanges are not true so the leak at the heads now, well, until i ran 2 gaskets.....
#20
I've gotten them to seal well now with the Percy's crushable gaskets I think.. first time I've used 'em so we'll see.
I really want a set of Kook's but.. u know how that is $$$.. I've had these since like Nov 01 or something...
#21
Check out Jeremy Formato/Rev Extreme in Tampa. I'm in the same boat as you LE2 head wiped out a LE2 cam and now have a 24*/25* i hand picked. I do need more get,and as we speak are working on 4.56's I already have a 4000 stall converter. I'll be using him for my dyno as soon as the rear end is done, for my engine/plus the 250 shot tuning. Here is his webpage with number.
http://www.fasterproms.com/
Jason
Jason
#22
23rd/24th of June?
http://www.ls1tech.com/forums/showthread.php?t=507644
#23
Jason
Jason
