Pros and Cons of programming out O2 sensors?
I had MadZ28 program out my o2 sensors but I am wondering if thats a good idea. I did it because one of them wasn't working. Should I buy a new one and have computer changed or what? I need pcm done for new gears anyway so thats no biggie.
Re: Pros and Cons of programming out O2 sensors?
Well, it is hard to pass emmisions w/o o2 sensors. It will run just fine w/o oxygen sensors. Alot of times, with a big cam, you will get added cam surge w/ o2 sensors.
Originally Posted by teke184
how is your car calculating a/f ratios if you have no O2 sensors??
The front O2's do the job of keping the motor running rich or lean. All the rear are there for is to make sure the cats are doing there job. When the comp starts seeing that the front O2's are reading the same as the rears it turns on you CEL b/c the comp thinks the cat is bad or not there.
Haha get them put back in man. O2 sensors are what sends the PCM the readings of oxygen in the exhaust stream during open loop, without them sending the info the car is either going to run how it wants, rich or lean. I don't know why you would take them out, if one isn't working replace it.
If i'm going to be putting LT headers on a 97 Z28, i only need the front 02 sensors then? I just want to make sure. Should i then get 02 sims for the back two? Thanks in advance
Dave
Im pretty sure he programmed it to run open loop constantly. I thought it was running rich so I will definitely get new sensor and have it put back in pcm. Thanks for all the help.
it would be programmed to be in open loop. you car runs in open loop when you first start it up and when you are at wot. I open loop you just have preset parameters and the 02 don't adjust anything.
