Pulley wont come off, help please
#16
Originally posted by will62085
with the ballencer puller, dont thread the bolts into the ballencer, use smaller bolts with nuts and washers on the other end
#18
Firehawk - I sent you PM
Shoebox or anyone -
So how do you get these 3 bolts off the Harmonic Balancer? Few of my buddies tell me to leave the serpentine belt on and socket wrench the 3 Harmonic Balancer bolts off. Uhh, the pulley moves! Then a mustang buddy of mines tells me to get a puller. Uhh, but the bolts are still on and I'm not pulling the hub! I forget what the correct approach is. Please help, I need to finish this opti change.
PEPPER
Shoebox or anyone -
PEPPER
#19
I know this may not be ethical but it works. Us the handle from a jack and wrap it with a towel. If you use the swaybar as a lever point it should come off fairly easy. You took the hub bolt out and tried to use a pulley puller. I would check the threads on the crank to make sure you didn't strip them. Anytime you put a puller on you need to put a dowel pin in the crank hole or else you'll be pushing against the threads with the puller. If the Hub bolt doesn't go back in properly you'll need a tap and die set to re-thread the crank. This is very crucial because you can through your whole setup out of balance and then you'll be pulling the motor. Good luck on this.
#20
You should be able to remove the 3 bolts that hold the pulley without too much trouble. In an auto trans car, the crank may move a little but once it comes up against compression, it should hold long enough to break loose. If you have a manual trans car, put it in gear and put the parking brake on. It should hold still, then.
#21
#22
Originally posted by Tires_Smokin
Uhh, the spark plugs are not in, same as the headers due to a header install "on hold"...so no compression. Now what? Put the plugs back in? If so, I guess I would have to turn the crank one revolution to build the compression back up. Or could I take another approach? This is my first time doing all this and everything is going well but I'm not sure if I'm doing this correctly. Seems like I cut a corner or two.
#24
Use a long extension (or whatever) and place it through one of the spokes on the pulley and jam it against a safe place where you won't cause any damage. That should hold it still to get the bolts off.
sleeperZ96BT
09-09-2015 08:28 AM
