Pulling crank hub off.
I got a puller yesterday to pull the balancer hub off, but it's not budging at all. I even broke a few threads on one bolt, nut flew off.
So I went to bigger bolts and nothing is happening. Yes the bolt is out of the hub. I would of put more force on it this time, but it felt like another bolt was gonna snap. And this is a borrowed kit from AutoZone. :blah:
Originally posted by turbo_Z
You have to thread in a bolt like the hub bolt you pulled out but about twice the length and push against that. if you dont push against a bolt then you will never get that hub off.
you can tap the threads and straighten them out, or at least I was able to, I still used a three clawed puller to get the hub off and you really just need to get a longer bolt that will bottom out that you can push on.
you leave the harmonic balancer on it and put the stock bolt in like 2 to 3 threads then put the harmonic balancer puller on it and press it off using the bolt then tap around the balancer lightly when you cant go anymore, then it should be able to pull off
I used a small piece of steel. (smaller than the diameter of the bolt. I did this as to not damage any of the threads on my crank. I then used a 3 prong puller with a socket pressed onto the end of the puller so that it would keep the steel rod from sliding off the end of the puller as I tightend it up. Pulled it off with no problems and threads look perfect. Hope this makes sense. kinda hard to explain. if ya get a small piece of steel and insert it you will see what I mean.
Mike
Mike
1- the bolt you put in the crank snout should be thinner than the crank bolt itself, so as not to thread into the crank, but just bottom out at the end. about 6 inches long is a good length. buy the strogest grade bolt you could find (grade 8 or so), cause trust me, if it bends in there, itll be a pita to get out. the one i had used was grade 5 or so, one bent inside, and the other worked, so........
2-KEY to getting it to sldie off, is to have it setup to pull as straight as possible. i suppose you understand this. itll come off smoooooooooth as butter if its straight
hth
hth
10-31-2016 11:09 AM
cyteone
02-07-2015 06:04 PM
Darth Xed
13
07-22-2002 12:45 PM
