Pulling motor... suggestions?
Ok I finally found the time to pull this damn thing. I am going to go step by step w/ http://www.michiganspeed.com/enginepull/index.html
anyone use this? any kinks? anyone have better advice? I was wondering if since my heads will be off and intake manifold off does it come out of the top w/ those off easieR? The oil pan is also off.
I am in the garage! checking on this periodically (when I get pissed)
thanks
thanks
Re: Pulling motor... suggestions?
ok so how do I put the chains on this block? The oil pan, heads, everything is off it. It is just the block... the last piston was in PIECES
I can get a cherry picker, and chains, so I just put them under the block and pull it up like that? thanks for the help
I got one of these: http://www.northerntool.com/webapp/w...3&storeId=6970
Notice on the end of the chains, those little tabs? I just got some short (1" or so) bolts with the same threads as head bolts and bolted one tab to the furthest bolt by #8 and closest by #1. Came right out, no problemo.
That leveler on the hoist can be bought separately if you already have a hoist, as well as just chains with the tabs. I didn't use the leveler, just the chains.
Originally Posted by 96LT1TX
yah, i can get that leveler, thanks a bunch man! Using the stock head bolts a bad idea for that or not? thanks again
cyteone
02-07-2015 06:04 PM
Darth Xed
13
07-22-2002 12:45 PM
