Question about egr blockoff.
OK heres the thing. When installing my new engine i got the EGR block off kit and put it on and now I have this problem where my car feels sluggish and has a rough idle(Rougher than the cc305 should),and surges hard just letting first gear take the car on idle.Sometimes the car will be pulling high RPM and then drop off and then pick back up again. I was wondering if there was anything that needed to be done along with just installing the plates.Also wondering if it could be a bad IAC.Also I cant let the clutch out slowly in first and let the idle carry it(car shutters hard and will stall).checked all the plugs,coil,and vaccum lines and blocked off the old EGR vac. hose.I am at a loss here.
Thanks,Sean
Thanks,Sean
