question about heads/cam to finish 383, and DCR
Old 02-13-2007, 07:36 PM
  #46
NightTrain66's Avatar
The TFS heads flow about 10-15 cfm better than my LE3 heads.
I KNOW what these heads flow and my 285 cfm claim on the LE3 is very conservative. The LE2 haeds with a 275 cfm claim is very conservative as well.
http://web.camaross.com/forums/showt...ighlight=Lloyd)
The RHS (Pro Aaction) heads that FASTFATBOY has started off at 64 cc and after angle milling them .130, they ended up at 50 cc's.
The problem with the TFS heads is that the valve seat is alot closer to the deck and after installing a 2.08 intake valve, you really cant mill very much before the 45 degree sealing angle on the intake valve seat is exposed and this limits how much you can mill them. You "might" be able to get them in the 59 cc range if the customer is willing to pay for angle milling and you are probably stuck in the 61 cc range with flat milling.
NightTrain66 is offline
Old 02-13-2007, 09:14 PM
  #47
FASTFATBOY's Avatar
Do you have average flow numbers on those two heads? I didn't know the TFS were like that, is it because the valves are twisted in the chamber?
So my heads barley outflow your LE3? At peak or average? Damn you make a brotha feel bad.
David
FASTFATBOY is offline
Old 02-13-2007, 09:20 PM
  #48
SStrokerAce's Avatar
TFS heads are just inline SBC heads like everone else has.
Bet
SStrokerAce is offline
Old 02-13-2007, 10:48 PM
  #49
Dave,
nah, forget the flow difference.
Your heads have the material to keep the air at 295-300 fps on the short side with a 2.08 valve flowing those #'s.
The LE3 heads end up with the air moving at 315 fps with a 2.055 valve at the lower flow #'. You run out of material before you get it any slower.
Your heads have the larger cross section over the short side and can hold that measurement further back up in the port. They are also larger at the PR pinch.
Old 02-13-2007, 11:53 PM
  #50
FASTFATBOY's Avatar
Dave,
So as you say"they move some wind"...I hope it goes like stink!
David
Old 02-14-2007, 04:50 PM
  #51
firehawk408's Avatar
For anyone else who stumbles apon this thread, in regards to Lloyd responding to his e-mails, he responded to me twice under a 24 hour period with a lot of great info for FREE. Thanks for the help Lloyd.
firehawk408 is offline
Old 02-14-2007, 10:31 PM
  #52
reamo04's Avatar
yeah, he got to me and appologized for the inconvenience as soon as he saw this thread. My guess is that it went to his junkmail for some reason, idk.
def. a great guy to work with tho, he's helped me straighten everything out and gone far beyond my expectations
reamo04 is offline
Old 02-15-2007, 07:03 AM
  #53
94_camm's Avatar
I got the TFS heads..then sent them to Lloyd to get ported..they flow pretty good.... i do believe they flow 298.I Would be another to vote for Lloyd Le3 Package!
94_camm is offline
Old 02-15-2007, 07:28 AM
  #54
Z-RATED94's Avatar
A few years back while asking for help on which way to go for a mild setup that would pass emissions you were all very helpfull. At one point I called Lloyd to see what a set of heads would cost me. Nice guy to talk to as anyone thats called him will tell you. A few days later I had a few more questions for you gents and out of the blue Lloyd calls me just to help with the new questions I had. Must have talked for almost an hour. Now thats some great customer service.
Z-RATED94 is offline
10-31-2016 11:09 AM
cheapchevy
04-08-2015 08:48 PM
D1SC383LT4
01-26-2015 01:41 PM
Collector Car
01-05-2015 10:58 AM
F(ast)-body
02-26-2003 09:05 AM
Quick Reply: question about heads/cam to finish 383, and DCR
