question about injector size.
okay guys im building a 355 lt1 bbk 58mm throttle body k&n cold air intake just got the heads redone new vavles springs so on.. ive got the comp cam 276hr14 cam cc 1.6 rr and cc roller lifters im not sure what size injectors i should run with
you should have plenty of room with 36lb injectors. I built a 355 with the CC306 ported heads, the usual goodies and ran stock injectors and it ran fine.
10-31-2016 11:09 AM
