View Poll Results: Which Air Intake Kit
SLP
16
61.54%
K&N
10
38.46%
Voters: 26. You may not vote on this poll
Question about LT1 SLP Air INTAKE KIT
Old 06-30-2008, 11:29 AM
  #16
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I bought the SLP, but haven't installed it yet. I would guess there isn't a dime's worth of difference amongst any of them from a performance standpoint. Get the one you like the best. Personally, I thought the SLP had a higher cool factor.
BTC is offline
Old 06-30-2008, 05:16 PM
  #17
EnFuegoZ28's Avatar
Mine had the SLP on it when I bought it. Out of the CAI's I have seen I think the SLP looks better under the hood than the others. The only thing I don't like is having to remove, clean, and reinstall two filters instead of one.
EnFuegoZ28 is offline
Old 06-30-2008, 05:40 PM
  #18
reamo04's Avatar
dont get any of them
Lingenfelter supertube CAI
only like 160, a name you know, and a MASSIVE filter (bigger than the k&n or moroso units)
reamo04 is offline
Old 07-02-2008, 11:46 AM
  #19
Junior Member
99Ls1fever's Avatar
Thats cool you live in Kansas, I used to live In Hutchinson for 2 years... Can you give me a link for the Lingenfelter C.A.I. That would be awesome...
99Ls1fever is offline
Old 07-02-2008, 12:05 PM
  #20
hghpwr's Avatar
I have the slp and I also don't like taking it off and cleaning it,the filters are at an angle which makes it hard to install and remove.If I bought another one I would try the lingenfelter.
hghpwr is offline
Old 07-02-2008, 02:56 PM
  #21
reamo04's Avatar
http://www.lingenfelter.com/store/l650400493.html
the filter is seriously 2x the size of a k&n.
reamo04 is offline
Old 07-02-2008, 03:45 PM
  #22
sc1twntrbo's Avatar
just because the filter is bigger doesnt mean the engine will need to suck up the extra air a bigger filter will give. there was an article on the subject about 10 years ago in carb setups and the larger filters sometimes hurt performance but most of the time didnt make a lick of difference.
sc1twntrbo is offline
Old 07-02-2008, 04:04 PM
  #23
reamo04's Avatar
theres an article floating around on here comparing all of the different CAIs, look back around august of 07 IIRC, because thats when i bought mine. I went with the lingenfelter because it was the most proven.
reamo04 is offline
Old 07-02-2008, 04:16 PM
  #24
stockssn2o's Avatar
factory lt1 ss airbox and hood FTW just don't nitrous backfire... they blow apart
stockssn2o is offline
Old 07-02-2008, 06:35 PM
  #25
wrd1972's Avatar
Arizona speed and marine and Moroso IMHO is the best due to the metal tube that the filter clamps to. It allows you to torque the filter down so it will not fall off. K&N is total crap due to the plastic tube. Both of these do NOT require removing the bottom panel in order to access the filter.
I have the AS&M now and am very happy with it. I have also had the Moroso which is a lot cheaper. Cant go wrong with either of these.
wrd1972 is offline
Old 07-02-2008, 06:38 PM
  #26
ninet1gt's Avatar
i have an slp on my car now and am not a big fan, it doesn't fit that well, it's not even held on by a bolt, it just slides into a spot i'm assuming that the stock air box fit in, it's a pain to get in or out (might be because of the tf elbow too), and i've always been taught that one large pipe will out flow dual smaller pipes, so keep that in mind too!
ninet1gt is offline
Old 07-08-2008, 12:55 AM
  #27
sonia93's Avatar
Originally Posted by GreenGator
I dont know the SLP, but... if that is the one that has the metal tubing I would figure that that would heat up the fastest and probably stay hotter longer than the K&N, which is plastic? Just throwing that idea out there.
Thats the same thing I heard.
sonia93 is offline
Old 07-08-2008, 06:47 AM
  #28
Junior Member
99Ls1fever's Avatar
Seems like the Lingenfelter is becoming the overwhelming winner in this after all....
Old 07-08-2008, 06:49 AM
  #29
Junior Member
99Ls1fever's Avatar
See thats what I was woundering back on page one or so about if there filter size matters for air CFM intake or not....
Old 07-08-2008, 06:51 AM
  #30
Junior Member
99Ls1fever's Avatar
Do you have pics for us, so we can see the setup
Quick Reply: Question about LT1 SLP Air INTAKE KIT
