question about moving battery to the trunk
if i get like a dry cell or somethin, do i still need to put it in a box etc etc and vent it? i dont wanna vent the box, and whats the trouble i hear about starting with battery in t he trunk?
Originally posted by glennxx1
how is venting easy? i thought you had to cut a whole for the air to get outside?, and is a "dry cell" lighter than normal batterys? ---you use zero gauge wire?
If you arent willing to drill a small hole, i would say dont move your battery
Originally posted by furely
I use an optima battery and do not have to vent it. I pass all tech inspections. I also have no trouble starting my car. I used 1 and 2 guage wire.
8:1 In lieu of rear firewall, battery may be located in a SEALED .024 inch steel.....box. If sealed box is used, box cannot be used to secure battery, and must be vented outside of body.
can i get optima battery at auto zone? what exactly would i ask for at there? just say "an optima battery" ? what volt is it
squarehead
11-21-2014 08:02 PM
