Question about removed engine
I dropped the engine/trans from the bottom with a jack under the tranny tailshaft and one under the k-member. If I now remove the tranny from the engine, will the engine/k-member assembly still balance on the jack? If not, what's the best way to balance it until I'm ready to put the engine on the stand?
Rather not find out the hard way!
Re: Question about removed engine
Yea just hoist it up if you have one, then slip the dolly under it. That way you can roll the assembly around on the dolly when you need to. Makes it so much easier.
07-04-2005 05:00 PM
centric
08-15-2002 09:04 PM
Darth Xed
13
07-22-2002 12:45 PM
