Question on catalytic converters
Old 01-24-2004, 02:49 PM
  #16
N2OpwrdTA's Avatar
Originally posted by madhatter
I don;t know about highest flowing, but you are tlaking aobut a +/-5 hp difference. Nothing to worry about.
Yeah, and Im sure youre not running an airfoil or K&N or syn lube or no cat or good ypipe or cutout or exhaust or descreend maf or TB coolent bypass, etc I think its funny as hell when people make comments like that. It all adds up. im happy with 5hp any way I can find it.
N2OpwrdTA is offline
  #17
SnakeSkinner28's Avatar
No you cant gut it and pass the test, at least ive never EVER seen that happen, but you might get lucky. Get a random tech cat, for about 250. Those cheap ones that cost 45-100 are not direct fits, meaning they would have to be welded to your intermediate pipe, you dont want that. Random Tech will bolt up to your intermediate pipe via the flange and it will weld to your ypipe just fine. That would be what i would do if you absoulutly have to pass emissions.
SnakeSkinner28 is offline
Old 01-24-2004, 04:38 PM
  #18
Eliminator's Avatar
It won't pass if it's gutted, you could buy an off road pipe and put on your car, then put the cat back on when it needs to be inspected. The thing is i only did mine so i wouldn't have to pay for ANOTHER cat. [/B][/QUOTE]
Where do you get the off road pipe? I new heard or seen it in mags.
Eliminator is offline
Old 01-24-2004, 08:27 PM
  #19
bigde4u's Avatar
here you go:
http://www.thunderracing.com/index.c...yid=1052#T1458
bigde4u is offline
Old 01-24-2004, 09:14 PM
  #20
Fatdog's Avatar
Catco
Fatdog is offline
Old 01-24-2004, 09:20 PM
  #21
Fatdog's Avatar
Question
Dam,guess you might try the Random,because yesterday I had about 2300 posts,and was a pominent menber,today I have only 450 posts,and I'm a new member again..Oh well,forget the catco,sorry guys.
Fatdog is offline
Old 01-25-2004, 05:28 PM
  #22
Eliminator's Avatar
Originally posted by bigde4u
here you go:
Thanks for the info.
Old 01-25-2004, 06:24 PM
  #23
remaxracer45's Avatar
where can a guy get a orp for a 97 z to make the cats go bye bye?
remaxracer45 is offline
Old 01-26-2004, 07:49 AM
  #24
Eliminator's Avatar
Not worried about the emissions test in Wisconsin?
Old 01-26-2004, 08:16 AM
  #25
94TA/GT's Avatar
I put on Jethot coated MAC midlengths and ypipe. Also got a coated orp. With my Borla catback it's way too raspy (with larger or smaller plate) with the orp.
Ended up getting a coated MAC cat from Jethot also.
Has a ball & socket on each end so it bolts right up to the catback & ypipe. Easy removal if I want to run the orp again. Sounds good once again.
Price was $200
94TA/GT is offline
Old 01-26-2004, 11:17 AM
  #26
Never recieved anything to get one and had the car for four years? I'm in the military and push came to shove i'd register it in aonther state. I have a obd1 conversion and tune so i'd be jacked either way.
Old 01-26-2004, 11:28 AM
  #27
lazygearhead's Avatar
Not to jack the thread, but it seems on topic. What does a bad cat sound like? I have a 88 Monte Carlo SS that I just swapped a LT1 into this summer. I have long tubes and true duals, but I also have high flow cats. I have a real bad sound that I originally thought was valvetrain, but driveability never really was lost, and I relashed the rockers the other day, and everything looked great up top.
I also prodded the exhaust with a stethascope, and while I can hear it in all the primaries on the passenger side, it is definately loudest in the passenger side cat section. So, I think my 5 month old cat has gone bad. It sounds kind of like gravel in a blender. Oh yeah, one more thing. The sound originally started after I goosed the throttle, but now is present all the time in normal driving, and I have put too many miles on it to be a bearing... it should have failed by now. Any thoughts?
lazygearhead is offline
Old 01-28-2004, 11:20 AM
  #28
thefox1's Avatar
Well, I had the cat gutted, and what a difference! Must of been a long time coming. The porcelin in front was all melted !! But now it's like getting a 2 for 1, more power and better sound
thefox1 is offline
Old 02-08-2004, 11:04 AM
  #29
b-stevens's Avatar
94TA/GT, did you have to use the starter pipe in order to use the MAC catalytic converter? How much was it coated from jethot? most sites have them listed for 220 to 230 alone.
b-stevens is offline
Old 02-08-2004, 11:05 AM
  #30
Bud M's Avatar
lazygearhead:
Cats fail in different ways so there is not one answer to your question. Sometimes they melt and clog up and sometimes they burn out. I've seen my muffler guy bang on the bottom of the cat to see if he could hear any rattling sounds inside. On my Jeep I could hear a difference when I started the car when my cat went bad.
Bud M is offline
ChrisFrez
02-15-2015 07:49 AM
rwferguson43026
02-06-2015 10:06 AM
30thZ4C
Wheels and Tires
01-29-2015 06:03 PM
Geoff Chadwick
07-31-2002 12:07 PM
Quick Reply: Question on catalytic converters
