questions about Comp cams XE 224/230 cam
Re: questions about Comp cams XE 224/230 cam
That was a great daily driver cam
As mentioned about the springs, there's no way in hell I'd try stock springs with that cam. That's just asking to throw $ out the window after the damage occurs.
For stall, it depends on your gears and use of the car with that cam IMO.
I agree with all the guys saying don't use stock springs!!!
The lobes on this cam are too steep for stock springs... you're just tempting fate if you try it. I'm using the 918 beehives.
The cam is no problem for daily driving... even the gas mileage isn't too bad. There's just enough of a humpity-hump idle to let everyone know it's not stock, but it idles fine (@900) and drives great.
oldschool
02-09-2016 09:21 PM
