Questions about my first LT1:)
#21
Re: Questions about my first LT1:)
Originally posted by Erfanz28
Hi Guys,
I just picked up a 1995 LT1 TA with 120k miles and the mods are as follows: 306cam, ported heads flow #255/193, 30lb Ford Motorsports injectors, hooker LTs, 2.5in y-pipe,SLP Loudmouth, CSI WP, 58mm BBK TB, 1.6 Pro-Magnum Roller Rockers, 10308-1 Spring, Cloyes Double Timing chain, CC "R" lifters, 160 degree Thermostat, Hurst shifter, Lou's short stick, port and polished Mass Air Flow sensor, K&N Cold Air Intake, Eibach springs, LGM Adj. Pandhard, MSD coil, Nitto DRs, Throttle Body bypass, BMR adj. lower control arms, LT1 Edit.
My question is that it has two disconnected o2 sensors since they are out. The car bucks and jerks and just runs real rough when your foot is off the pedal coasting in gear, but if you give it gas and get the rpms up it stocks bucking and jerking. It has the stock optispark. My question is that with the o2 sensors disconnected since they have gone bad, would that cause the car to run really rough and also it has the stock fuel pump and it has a hard start problem.
Erfan
Hi Guys,
Erfan
#22
Re: Re: Questions about my first LT1:)
Originally posted by FacelessZ
Dude you just bought my buddy Scott's TA. Its loud as hell huh? It's a quick car...I can vouch! I know he was running it in open loop...
dluna333
15
03-13-2015 12:30 PM
jasonduaine
03-07-2015 09:44 AM
Hurin
12-13-2014 07:38 PM
