Quick oil pan ?
Quick oil pan ? Motor finished just need a bigger pan.
Just wondering if there is another pan that fits the LT1's with no modifications? Canton is back ordered for 3 weeks, I leave on deployment in 1 week, and My motor is only lacking this dang oil pan. I have the HV pump and won't settle for the stock pan. I have found one but I wonder if anyone is using it???
Milodon
Milodon
Stroker Pan
I bought the miloden stroker pan and it fits just fine. However I am using an aftermarket K-member. I am unsure as to which pick-up to run right now but otherwise I test fit the pan and if clears the crank and the rods. I am not sure if this helps out at all.
Later Colin
Later Colin
It will not fit a factory Kmember in a 4th gen, unless they have changed the pan design from two years ago. Best of luck, you can try and get a pan from TPIS, etc... these places commonly stock the pans.
