Quick Question
#16
#17
Re: Quick Question
Experience indicates that the only reliable Opti is the GM (Delco or Delphi) unit. Everything else seems to be a real crap shoot - off brands might last for 10 years, might last for 10 minutes, might be bad out of the box. And all of them need the rotor screws tightened with Loc-tite, or the rotor may fall off.
#18
Re: Quick Question
#20
Re: Quick Question
Oh and like has been said, i bought a cheap ebay opti, installed my msd rotor, and had no issues with it. Ive bought remans from local store that were junk, its a matter of luck i think. Someone called thepartsladi used to sell optis cheap on ebay, dont know if she still does?
#22
Re: Quick Question
ok guys. i pulled the coil wire off the opti. had my g/f bump the key and it shocked me. my guess is....its gettin fire. but when i did the same thing to a spark plug wire. nothing. so my guess is the opti went out again. my question is this. before i go tearing down the front end of the motor. is there any sensors or fuses that would cause the opti not to work? shoebox. i checked around. u were right. best i can do for an ACDelco opti is $375.74
#23
Re: Quick Question
If you are getting spark at the coil, the optical section of the Opti is working fine. If the spark from the coil is not getting to the plugs, it would indicate a problem with the contact of the coil wire in the Opti cap, a rotor that has come loose or lost it's contact, or a damaged Opti cap.
I would retest for spark from the Opti by using an insulated plier to hold the wire close to the block, and observing the spark. Do the same with several spark plug wires. You are dealing with upwards of 20,000 volts
#24
Re: Quick Question
#25
Re: Quick Question
Obviously, you can replace the whole unit, if that is what is required, but if your issues are only with the cap and rotor, you can just replace only those. The mileage on the opti and what you see when you get it apart might help in making that decision.
#26
Re: Quick Question
Yeah I would pull it apart and take the cap off before you buy anything. You may just need a rotor. Cheap rotors have been known to self destruct or as he said, just come loose and fall off. Open her up and see what you got. Maybe youll get away with a cap and rotor kit!
#27
Re: Quick Question
#29
Re: Quick Question
alright. so i tore the front end apart. put loctite on the screws. and then put the car back together. the car is slow to crank. but it actually does crank. it has a "rough idle" to say the very least. it runs like its hittin on about 3 cylinders and then after about 3 seconds. it dies again. so im half way to where i wanna be. but what could be the problem? ive double and triple checked the firing order. checked the plug wires and made sure all the wires are secure to the plugs and opti. WHAT AM I MISSING????? any comments will be greatly appreciated!!!!!!
Thanks,
Jared
Thanks,
Jared
#30
Re: Quick Question
Are you sure you have the cam dowel pin correctly indexed to the back of the Opti?
Courtesy of Shoebox:
http://shbox.com/1/opti_back.jpg
You'd be amazed how many people manage to screw that up.
Why not add a "Signature" so people know the specific details of your car, and don't have to go back to the first post in the thread to find basic info like the year?
