Quick Question
#31
Re: Quick Question
Are you sure you have the cam dowel pin correctly indexed to the back of the Opti?
Courtesy of Shoebox:
http://shbox.com/1/opti_back.jpg
You'd be amazed how many people manage to screw that up.
Why not add a "Signature" so people know the specific details of your car, and don't have to go back to the first post in the thread to find basic info like the year?
#33
Re: Quick Question
The PCM sets codes for faulty injector circuits. Do you have those codes? Do you have 12V at each pink wire in the injector harness clips? Check for the PCM supplying the ground to fire the injector by using a 'noid light. PCM seldom fails.
#34
Re: Quick Question
Are you really sure? I'd estimate at least 10% of the people who are"sure" found out later they were wrong.
#35
Re: Quick Question
alright so heres what happened. i tore the car back apart and put the opti back on. it was on wrong. i suppose it moved when i was putting it in place. but the car is running. as a matter of fact. it runs great! and its idling perfect. but im still getting 2 codes.
P0300- Random/Multi Cylinder Misfire.
P0113- Intake Air Temperature Circuit High Input.
no idea why.....any guesses??????
#37
Re: Quick Question
yeah i cleared all the old codes out once i got it running. drove the car about 8 miles. Check Engine Light popped back on and that was the codes it gave me. that light has been on for the last 3 years and its always something retarded like that. but i dont see how the car runs as smooth as it does and supposedly have a misfire.
#38
Re: Quick Question
Check the IAT sensor to make sure it's plugged in. The code is telling you there is an open circuit, or a short. If the harness wire is OK, check the sensor:
4th Gen LT1 F-body Tech Articles
P0300 is indicating a random misfire. It's derived from the crank position sensor rotational velocity, so is can actually be caused by an aggressive cam (don't see one in your signature), or even from driving on excessively rough roads.
Not sure why you consider those codes "retarded"????????????
#39
Re: Quick Question
01-23-2015 01:13 PM
