Quick question about my rocker adjustment
I just adjusted my rockers and everything is much quieter now, but I was wondering just how tight each polylock will feel when setting the preload. I turned 1/2 turn past zero lash like the instructions said. Should it be a tight feel as I'm setting preload or is it really easy to turn the preload?
I'm just asking because I've never set it before and I don't have the feel for it. I'm hoping the rockers aren't too tight now as opposed to too losse before.
Mine were somewhat hard to set preload and it had me a little suspicious. It kinda idles rough right now, but everything is quieter. So I'm thinking they are too tight. I think I will take advantage of my little "lack of oil in the valvetrain" situation and adjust one more time while engine is running.
poly lock and pre-load are two different things. the lock just keeps the rocker nut from coming loose. some of mine were pretty easy when setting preload. i was doing it with a warm engine though so that might make a difference. when your putting the lock on just make sure the rocker nut doesnt move so have a wrench on it when tightening and you should be good to go
oldschool
02-09-2016 09:21 PM
kev93z28
08-19-2002 12:48 AM
