Quick question. Please look...
Ok... So I had the infamous intake manifold leak so i pulled the intake and replaced the gasket and did the egr blockoff and so on.. put everything all back together, connected everything and waited a few days for the permatex to set.. i started it up a little bit ago and the fans came on right away. any reason this should be happening? i thought it might have been my manual fan switch, but i turned the car off and tested the switch and it was working fine. any idea why my fans would do this? is it just because it's been parked for 5 months? i appreciate your input.
What year car? If you deleted the EGR solenoid, it'll set a code, which will trigger the light and fans. You need to pop a resistor in place of the solenoid. That is, if you have a 94-95. OBDII cars are different.
68camaroboltz
10-05-2015 11:56 PM
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
NewsBot
09-14-2015 09:20 AM
