View Poll Results: Quietest High-Performance Cat-back
SLP 2OTL
14
29.17%
Flowmaster
12.50%
Hooker
11
22.92%
B&B Tri-Flo
10.42%
Magnaflow
16.67%
Corsa
8.33%
Voters: 48. You may not vote on this poll
Quietest Cat-Back Exhaust
My current exhaust is Borla cat-back. Its top notch exhaust, but too loud. After my new setup its louder than before and I can't drive on the street. (Cops are the first reason).
Any way I want quietest cat-back exhaust. My current setup is 383cid 210cc AFR heads (expect 500 crank hp) so I don't want to lose lots of HP after cat-back changed.
BTW: I searched, but found just a few topics about this subject. I added POLL. I didn't add GMMG Cat-Back, because its same loud as Borla.
Re: Quietest Cat-Back Exhaust
I am guessing you have hearders?? If ya wanted something quiet, but still have a good tone to it. I look at dynomax.. My buddy had it on his formula.. Sounds really good..
But about the borla.. I'd be interested in buying it.. Whatcha wanting for it?
When I put my flowmaster single out rear catback on, I couldn't tell a difference in the sound level over the original at idle or cruising speed. You can make it louder and throatier without a cat though. I think it sounds really nice without cats and is still at a reasonable sound level. The only time it may get annoying is on the freeway with the tops off at the rpm where resonance occurs, but you learn to like it
i know what u mean, check my sig my parents are bitching to all hell
Originally Posted by GT KILLER
See, I'm different. I want the loudest possible cat-back, when I get it. I have my sights currently set on the SLP Loudmouth.....
Originally Posted by mattybz28
That's because you're a ricer.
So you mind enlightening me on how you supposedly mustered a 13.3 at 103 with an otherwise stock car that only has intake and catback on it?
Originally Posted by kick Z tail out
Hmmm... Okay...
I have Kooks LTs Headers and Y-Pipe (with cats).. As I said above I don't want lose performance too much, so stock exhaust will not be my choice. It also should flow well.
Not only is the B&B quiet but it has a nice tone at idle which wont set off alarms but still lets you know that the car means business while at WOT you can hear one hell of a sweet scream! My friend runs it on his TA and I seriously considered one for my Z.
Here's a thought, douchebag. Before you go assuming things, how about you at least get to know me a little? Good God man......
