Rad hose collapsing after water pump install
First let me list what all has been checked and replaced, ive checked the return hose to the reservoir, no blockage, new cap from my job at Griffin Rad, 2 of them, new hoses, all rad hoses!, Bled the system per proper procedure, about 90 times, lol, Now for when it happens, after driving it normally to operating temp, upon cool down period is when it sucks shut, if anyone has any ideas of what to try now please let me hear them This is all happening to a 1997 ss camaro. Oh new thermostat also.
Re: Rad hose collapsing after water pump install
Which hose is collapsing? Upper? lower? When you open the radiator cap, does the hose reform to normal? What is the level in the radiator and overflow reservoir after opening the cap? Sounds like some kind of flow problem(blockage) and you are pulling a vacuum in the system somewhere.....but I'm not completely sure of that. Does it overheat when driving now? What is the temp when cruising on the highway?
Please post a topic only on one forum and take the time to respond to people who try to help you. Do not start a new thread.
This is Injuneer's response to the other thread....
This makes the most sense. Replacing the hose from the radiator neck to the reservoir take might fix it. Maybe some kind of a one way blockage in the hose. Might also be that he has the wrong type rad cap.....might have a 18psi cap that only is "one" way.
If the above is the case, his overflow tank level will rise over time if he is topping off the rad after each event. If he is not topping off the rad, the overflow level would remain constant "hot level"(even when cold) and his low coolant light may cycle on and off depending on rad fluid level.
Is it possible the rubber hose from the cap/neck to the reservoir is also collapsing under vacuum, preventing the coolant from flowing up the hose? The stock hose is fairly flexible.
It's obviously allowing coolant to flow out of the reservoir as it expands and heats up, but not flowing coolant back into the radiator as it cools down and contracts.
10-31-2016 11:09 AM
