Radiator drain valve stuck!
Re: Radiator drain valve stuck!
I broke both ears on mine and ended up heating it up with a propane torch and removing it with some pliers. The downside is you will need a new one, but you'll probably brake your old one anyway taking it out. The new ones are cheap and they come in packs of 5 or 10 if I remember correctly. I got a few of them left in my garage.
You can also try heating it up just a bit, without melting it.
30 minutes?! I didn't know that little piece of plastic would hold up to that much. Just get some needlenose pliers, get a good grip, and turn. It will either start to move or you'll just get the end of it in your hands and have to drill the rest out.
Magenta_Hearts
03-29-2017 08:54 PM
