Radiator not held tight after a/c delete
I just finished yankin' all my A/C stuff off, and when the radiator went back in without the condenser, it is not held in tight enough. Anyone ever run into this prob? Solutions? I've got a Be Cool aluminum radiator. THanks...
I had to modify the bottom on the tray and also drilled new holes on the radiator schroud to shift the radiator forward. This causes the radiator to sit at an upright position instead of an angle. The problem with this is that you had to hammer on the inside liner of your hood because the radiatar cap will hit.
Noct
07-14-2015 01:18 AM
ducttape1975
07-10-2015 06:29 PM
