radiator removal question
i'm replacing the inlet tank on my radiator, but am having a bit of a hard time pulling the entire rad out.
the basic removal i found was fairly simple (ie. taking fans out, disconnecting hoses, etc.), however the last and only thing i'm having trouble with is disconnecting the rad from the a/c condenser.
the only reason for this is cause i can't disconnect the bottom corner on the passenger of the condenser without worrying about breaking or flexing the steel lines going into the condeser.
any suggestions, pics, or guides would be greatly appreciated.
Yeah that part is kind of b. The lines are actually pretty durable (to the point where people move the condesor WAAYYY out of the way to install a CAM). You just have to muscle it out of those slots, your AC lines will be ok.
Sean
Sean
10-31-2016 11:09 AM
07-04-2005 05:00 PM
