real quick question
real quick question
How many bolts hold on the opti, and where are they? I have the waterpump off, and i got to two top bolts, but i can't seem to find any others. Are they behind the flywheel?
The flywheel is actually on the opposite side of the engine. But Im guessing you mean the crank hub. And yes you need to remove that to get the opti off. Number of bolts....I dont really remember but like I said if that crank hub is on there it would get in the way of removing the opti. I think its like 5 or 6 bolts.
