A really asinine question
Yeah, on my automatic '95 Z28 I have 3.23 gears. On the shifter, what the HELL is that button on the top for? As far as I can remember, I can shift with or without it being depressed.
I have a 94 a4... and on mine I need to use the button when downshifting out of OD into D, D into 2, 2 into 1, Into or out of Reverse, etc
I might be wrong on a couple, im not sure
When starting in 1st, I can shift freely into 2nd, drive, od, and neutral without depressing the button.
Re: A really asinine question
The idea is to prevent it accidentally going into park which bends up a few things if you are moving and makes lots of clanking sounds. The additional idea is that you push it to get out of Park, then release it and pull back on the shifter which will stop in OD. You don't have to look or guess. In normal driving you should never have to look at the lever or the indicator.
It also allows you to "rock" the car to get it unstuck from mud or snow: just push forward to R and back to OD. Useful here in the snowbelt.
Many people don't realize that I guess.
Yours need adjustment.
Re: Re: A really asinine question
And what time will you be coming over to clean the coffee out of my keyboard...?
dluna333
15
03-13-2015 12:30 PM
jasonduaine
03-07-2015 09:44 AM
Hurin
12-13-2014 07:38 PM
