Rear Main Seal Leak?
I've got a 1995 Formula V8. I recently just replaced the intake manifold gaskets because it was leaking.
However, I am still leaking oil. I noticed there is a lot of oil on the back of my oil pan.
I think it is the rear main seal that is causing issues. Anyone know where it is located. How difficult is it to replace?
http://shbox.com/1/rear_main.jpg
- Z28WannaB
- Z28WannaB
Re: Rear Main Seal Leak?
This is the rear main seal and its housing. Its located between the engine and trany, you'll have to remove the trany and the flex plate to get to it. It could also be from the oil pan gasket, and that requires liftling the engine 3-4" up. Leave it to the next rebuilt if the leak is not that major.
The Oil pressure sending unit can leak?
You know, I figured it was just like all the other f-body guages and was innacurate. But maybe you know.
My fuel pressure gauge, is kinda spuratic. It obviously goes up and down as you apply more gas and let off. But it kinda twitches noticably.
Is that anything to be concerned about? Could my sending unit be going out?
Back to the main rear seal, anyone know how to locate it? And is it difficult to change?
- Z28WannaB
- Z28WannaB
Like sssalah said, it's behind the flexplate/flywheel. Its known as a 1piece rear main seal. Most don't go bad, unless blowby is excessive and blows them out of the retainer. If you go there,, you need the seal and the retainer gasket.
Doug
Doug
Here's a link to my write up when I fixed my leak. I had to replace the oil pan gasket because it was leaking also. These pictures will look familiar once you get the tranny out and flexplate off.
http://www.pharmacy.arizona.edu/staf...RMainSeal.html
Good luck,
Good luck,
- Z28WannaB
- Z28WannaB
How long ago did you reseal the intake ? did you clean old oil off trans and engine ? Just wanted to mention this because if you have had an intake leak for a while there is going to be a lot of residual oil still dripping off engine and trans, mostly when engine is warm.
Originally Posted by 97WS6SCharged
You still have to raise the engine a little bit to get the pan off of the front two studs that GM used on the LT1. What a pain.
Not on my car you don't. I just had mine on and off last night before an event today. Not sure if yours is different but I have 2 studs in the rear and my fronts are 12mm bolts vs the 10mm bolts along the sides. I don't have to jack squat up to lower my pan and replace the gasket.
squarehead
11-21-2014 08:02 PM
