Rebuild or Replace??
I have a lt1 with 115,000 miles on it, in a Z28... I was told that I need a crankshaft kit to stop the engine from making a grinding type of noise when I start it up. I'm wondering should I do a rebuild with the crankshaft kit or simply purchase another lt1. Keep in mind, that I am a college student and looking to spend $2500.00 max. I need some opinions on cranks, piston, and etc also... Thanks to everyone, any information would be helpful.
Re: Rebuild or Replace??
I don't know about needing a crankshaft kit because of grinding during start up. Hows your oil pressure and are you leaking oil out of the rear seal? How does it sound when it is running, any knocking noise?
Standard or automatic transmission? grind noise when starting is usually the starter or flywheel. a loose or broken bolt on the torque convertor or a cracked flex plate will make a knocking noise. I just don't know how anybody could tell you you need to replace your crankshaft without a tear down of the motor.
I definitely think so too... But its and automatic, I started it up yesterday and its more like a squeaky, squealing noise... It's definitely coming from the motor. Next time ill get a video and post the link.
Ok here is a video I found on YouTube of another LT1 making the same noise as mine, hopes this helps what I was describing to you guys. Copy and paste it in your browser.
https://www.youtube.com/watch?v=6mHq...e_gdata_player
10-31-2016 11:09 AM
Sergio
01-27-2016 04:27 PM
