Rebuild ?'s
Old 08-02-2004, 10:47 PM
  #16
Dave88LX's Avatar
Re: Rebuild ?'s
Originally Posted by S8ER95Z
Funny Dave, I drove mine for ~2.5 miles..no clack...just seized. LMAO..Moral of the story..if something doesnt look/sound right..just have it TOWED!!!
Member of the "Something broke and I drove it home anyways" Club.
Yeah hehe, I knew it was hosed to some degree anyways, no point of being hosed AND walking.
Dave88LX is offline
Old 08-03-2004, 08:43 AM
  #17
The Cartel's Avatar
Re: Rebuild ?'s
Originally Posted by Wild1
Yes, studding the mains with ARPs you will utilize the full depth of the threads versus a bolt which doesn't seat to the base of the hole. This provides a bit of extra grip on the bottom end where needed.
Wow learn something everyday... I think I'm going with your 383 set up, any more wisdom to share?
Daniel thanks but no thanks
The Cartel is offline
Old 08-03-2004, 04:55 PM
  #18
Wild1's Avatar
Re: Rebuild ?'s
If you're looking for a core block, there was a decent guy out of Tennessee selling them for cheap. $200 on Ebay. A buddy bought one for his 383 and it turned out great!
Wild1 is offline
Old 08-03-2004, 05:41 PM
  #19
The Cartel's Avatar
Re: Rebuild ?'s
got one, but thanks anyway. Do you know how much horse that 383 kit will hold safely. Trying to decide if I should step up to the 4340 stuff....
Old 08-06-2004, 12:56 PM
  #20
Wild1's Avatar
Re: Rebuild ?'s
With a stroker, not only will you be getting HP but also tons of torque. The cast crank should handle up to 550 HP at the flywheel (RWHP depends on A/T versus M/T). Always upgrade the pistons to forged and rods are stout if you go with the H-Beams. That way you can always play with boost or juice later if you want. Some say you can go up to 600 HP at the fly but that would be the limit...
Depends how streetable you want it and if you plan on pump gas.
Wild1 is offline
Old 08-06-2004, 03:52 PM
  #21
The Cartel's Avatar
Re: Rebuild ?'s
Yea, I've been talking back and fourth with Frank at Gofaststuff. The kits shown on web site are externally balanced the kits for the LT1 are internally balanced they start at 899.00 and the kit I'm prolly goin with is 1149.00 ( forged pistons). I do want to stay pump gas so I'm thinking 5.7 rods with flat top pistons. Block will get decked also but prolly not much. Heads will most likely be ported LT1 castings. I just am stuck now on a cam and if I'll need some bigger valves to utilize it. Any suggestions? I don't wanna be spinnin it to 7000rpm or nothin with a cast crank but my goal is 500 flywheel hp with loads of TQ.
Thanks Jason
Old 08-07-2004, 04:08 PM
  #22
Wild1's Avatar
Re: Rebuild ?'s
Sounds like you're on the right track. You'll get some good performance with what you have in mind. There are some good threads here on cam choice. Remember it is the Dynamic Compression Ratio that gives the power, not just the Static Compression Ratio. Many have had good success with a CC502 cam in your set up. A good port job would do wonders... perhaps a slight increase in valve size but there hasn't been much improvement with larger valves and seats... somewhat overkill.
Deck the block a bit... 0.015. Use Impala head gaskets at 0.029. You'll be good to go. (Disclaimer - I do not have my notes at this computer but I believe that is the correct thickness for the Impala head gaskets). Ideally, you'll want your quench to be 0.035-0.045.
Enjoy.
Wild1 is offline
Old 08-08-2004, 08:10 AM
  #23
The Cartel's Avatar
Re: Rebuild ?'s
Well thanks!! I have you to thank for the help. I haven't even heard of the CC502 so I'll be checkin into it for sure. Do you think if I went with the 6.0 rods it would be to much for pump gas? Also what clutch is the best to hold all this?
Jason
Old 08-08-2004, 09:12 AM
  #24
The Cartel's Avatar
Re: Rebuild ?'s
The cc502 seems pretty small? I have a cc305 in it right now, but I was wanting bigger since the last time I did a cam I thought I should of gone bigger. What to do...
cocopops
Cars Wanted
02-01-2016 06:22 PM
Ks0209
10-01-2015 07:32 AM
Bxlt1
09-29-2015 03:18 PM
Z Power
09-19-2015 11:19 PM
Quick Reply: Rebuild ?'s
