Reflash pcm for break in period?
All the mods listed below with the exception of the cam it'll be larger are going on/in my new 383. The pcm was tuned for the stock bottom with all of that stuff, will it be safe to use it with the 383 during break in or should I get it reflashed?
Thanks in advance,
Matt
Thanks in advance,
Matt
It'll be fine.
I would also argue that, as long as the MAF isn't max'd out (500+ rwhp), then the tune won't do that much anyway. The tune is mainly for idle issues, shift points, fan on/off, etc. . . anyway.
Mike
Mike
