Remounting the coil-need some help
I had to replace the front cover seal and am in the process of putting everthing back on. When I took the coil off it was mounted on two studs that had nuts on them spacing it away from the head. Under the head of the nut on the stud on the drivers side were several ground wires. On the other side was a backet with some device mounted to it with vacuum lines and electrical connections. Does this mount directltly to the head or does it go on the stud after the coil bracket. I know should have taken a picture or made some notes. Your comments or pictures appreciated.
