Remove cai for line lock?
Originally posted by drewstealth
Damn, that sucks. So if i just buy the one from summit which doesn't have the prebent lines. Would i have to remove it then?
Originally posted by BlownF1
Well that depends on where you put it. I would say so if you put it in the location I described above, which is where everyone usually does. It'd certainly be easier to do it properly if you pull the CAI, and with a little practice, that's not that hard to do. Do you usually pull the lower access panel or try to do it all from the top?
Did you do it from the top with the slp cai. I would think it would be impossible with the slp. If so let me know how you do it. K, nevermind i now see your sig. How did you put the filters on from the top?
I had the SLP one pre-blower, and did mine from the bottom, piece of cake. I watched a buddy reinstall his from the top though, and while certainly doable, he munched the heck out of the filters on the way down...not the way I prefer to do things, but it worked. <shrug>
I've got the Hurst Roll Control with the Thunder Racing pre-bent line kit. Well worth the $, IMHO. Some prefer to save some money and buy the line/fittings and figure out the mounting themselves, but I took the easy way out...besides, hunting down the parts seems to be the biggest waste of time for me. To each their own...
10-31-2016 11:09 AM
GA93FORMULA
07-24-2002 11:38 PM
