Removing Crank Hub
Removing Crank Hub
Ive read several mixed results.. I still have the Opti on and the engine appears to be seized (I cant rotate the hub to get the Opti Off) So I basically have zero space behind the hub to get a jaw puller on there. Someone recomended using a different style puller.. and I was wondering what they were refering too. Also I have a Harmonic Balancer Puller... Would this work if I used nuts and bolts ?? Looking for suggestions. Thanks.
i just threaded the crank bolt in there -- a few turns, and then used that to push against, it worked fine and didnt damage any thread, i dont know how other people do it, but i got this information of the net
lt1g3n i just threaded the crank bolt in there -- a few turns, and then used that to push against, it worked fine and didnt damage any thread, i dont know how other people do it, but i got this information of the net
10-31-2016 11:09 AM
cyteone
02-07-2015 06:04 PM
1LEThumper
07-14-2003 12:45 PM
