Removing hood liner....
Have any of you removed your hood liner and did it cause any issues? I'd think it would be alright seeing that the SS's came without them but I just wanted to see what those who have done it had to say. Thanks
Re: Removing hood liner....
Go right ahead and remove it. I did.
It's actually a fire blanket. If there ever were a fire in the engine bay, the flames would dislodge it and (hopefully) smother the flames.
Mine's falling apart, and there is such little clearance between the top of the motor and the liner you can actually see where the top of the motor presses against it. I think I'm going to remove mine also.
The previous owner removed the hood liner from the car. He claimed it reduces underhood temperature and improves e.t.s. I think he is full of s***.
He did some other off the wall things to the car also that I am currently fixing. Hopefully a trip to the junkyard will yield me a new liner, otherwise I guess I will be paying a trip to the local dealer.
Oncomingstorm22
01-22-2015 07:15 PM
CARiD
01-14-2015 04:00 AM
