removing throttle body for teardown and cleaning
Im replacing all gaskets, new IAC, new billet throttle body plate, and Im going to polish the outside too. I want to soak the whole thing in acetone to get every last bit of grime off. Is it a bad idea to saok it in acetone or should I use some other solvent to clean it with. I want to use something stronger that throttle body cleaner. And yes I plan on re-oiling the shaft.
i believe someone else on here does use acetone to clean their throttle body. i remember reading it before. you may want to make sure before you do it though because that acetone is strong. well, i know it works wonders in organic lab.
Acetone is pretty strong stuff, don't know what that would do to it. I cleaned mine up when I had the manifold off, I just used a can of carb cleaner and a toothbrush over the whole thing. It cleaned it up pretty well, got most of the black stuff off the inside too. I then used a wire brush and the dremel with a brush to clean it up a little more, here is how it came out.
07-04-2005 05:00 PM
