replace procharger or go heads and cam
hello i have 1993 camaro with ati procharger 10psi procharger bearings went i am in doubt weather to go through speding another $1600 on procharger. I have 9.3 compression lt1 stock ported heads and intake heads only flow in 235 range. ring gaps are a little wide i have a 224/236 114 cam in it now i belive before with long tubes and good tune i had around 575 hp fuel limited 42 lbs injectors. Procharger went at track so i cut belt off and ran it na with blower tune readings with datalogger slowed950 mv at wide open it ran a 13.20 at around 107 i figure that is around 350 to 360 hp.
What is the max hp i could get with a le3 heads and cam with 9.3 compression and headers and a good tune. car is a 6 speed iwant to at least be trapping 118 to 120 what would you guys recoment
Rebuilding your procharger is alot cheaper than $1600. I think its somewhere in the $800-$1000 range. dont call procharger. Call someone like EPP. Alot of times its cheaper to have one of prochargers dealers send it back.
lol talk to procharger then
the impeller hit the houseing new houseing $400 dollars new impeller $750 new bearings that are scattered $699 all with labor yes you can covert to d1sc specs for $1350 that covers the new impeller and houseing as part of upgrade but then the bearings and seals and labor to rebuild gear box trust me i talked everyone there. If some one wants to buy it from me and have the around $2000 dolllars worth of work i would sell the whole 2core intercooled kit -fmu and fuel pump for $625 shipped taht would be 2625 for d1sc kit i would give 2 pulleys to 3.7 and 4.25.
now on the heads and cam pack i am talking durability and ease of working on and. I do all own labor so that is out i am asking does anyone have a le3 heads and cam and t56 car with dyno numbers that is it
thanks
ryan
thanks
ryan
10-31-2016 11:09 AM
