replace rotor and cap ?
i have a 1996 z28 with a 140,000 miles . i am doing a complete tuneup , should i replace the opti or just rotor and cap . also , what are the cheapest o2 sims that plug in . any help is appreciated . thanks
I ordered a MSD rotor and cap kit for my lt1. I will be installing it tomorrow. Its a pain to install, the water pump and balancer have to come off for it to be installed i will repost the results tomorrow night or saturday when i get it put on....The price from Jegs was $177.22 shiped COD.
Is it bad? If not let it be, you will never have another one last as long as the original.
If you do change it, do the whole thing. Jason sells them for @ $240, if you just do the cap and rotor it will not last as long.
I would replace the opti as a whole assembly. As for the 02 sims, the plug-n-play ones usually run around 90 bucks for the pair. You can buy some cheapo ones off of ebay but you have to cut and splice them into the factory wiring harnesses.
i replaced my cap and rotor on my opti with used parts none the less and havent had a prob yet.but i will be replacing my whole unit with a new one when money permits.but as for the install its not bad.i did mine at the max in about 2hrs.well anyways goodluck man.
stockssn2o
05-25-2015 08:54 AM
