Replacing A4 dipstick seal?
I just installed a higher stall/tranny cooler in my A4 and I noticed that my tranny leaks after I took it for a short drive. Turns out the dipstick seal/gasket is messed up.
Can you replace just that one part or do I have to order a new tube? If you can, where do I get one and what's the correct name for it?
And finally, how hard is it to replace?
I just did this whole thing but I had to lower the engine and tranny to reach all bolts, so I'm hoping I won't have to do any of that again...
Thanks.
Thanks.
Originally posted by viperkiller
youll need to pull the middle bolt out of the tranny, and just slip the tube up.
the seal can be picked up at any part store
I still have my monster extensions so it shouldn't be too bad.
Dan_the_ManZ28
02-21-2015 02:01 PM
