Replacing Starter
Replacing Starter
Hey guys, the starter on my 95 Z took a crap today, so I am replacing it. I've already gotten under the car and try tapping on it with a hammer to get the car to start in order to get it to my cousin's shop with no luck. Therefore, I have no access to a lift. My question is, how hard is it to replace the starter on our cars? Is there anything that complicates it such as placement of other parts, etc.? And finally, can I replace it by jacking it up in my driveway? I've done starters before, just never on an F-Body, so I don't know what to expect.
Thanks, Keith
Thanks, Keith
I've replaced mine... well, actually had to drill out a broken starter bolt too... long story. But from what I've seen, you will need to drop your y-pipe.... Then it's easy and yes, you can do it in the driveway.
The hardest part will be dropping the y-pipe. If your bolts are really rusty and you brake them, you might need another weekend.
I'd spray them with some PB Blaster prior to removal. Some heat might help too.
I have the A4 and replaced my starter withouth removing the Y-pipe or tranny cooler lines. You do want to move/bend the lines out of the way. And the position the starter will eventually slide out is after you unbolt it, turn the starter straight up, with the starter gear at the top, and pull it through the bottom. You have to roatate it a bit,and once you do it once, you will never forget.
Oncomingstorm22
01-22-2015 07:15 PM
