by request new thread, hope this helps guys
Old 03-24-2008, 08:46 PM
  #16
96flame's Avatar
Originally Posted by black96z28
in the frist graph, the blue line is my car, the red line is the old lt1 record and in the second graph I had a bad O2 sensor.......
Well that makes more sense knowing that. Your bad O2 really doesn't play a role in WOT. If anything it would add extra fuel.
96flame is offline
Old 03-24-2008, 08:54 PM
  #17
Mtxz453's Avatar
yea your bad O2 definetly would not make ur car lean. Everyone's obviously telling you to check your rod length by someone else, so go do it, the ones you have are obviously way to long.
Mtxz453 is offline
Old 03-24-2008, 09:05 PM
  #18
Josh'95Z28conv's Avatar
Dude, your pushrods are too long. I dont know if that could result in valve float, but there's a pretty good chance.
Josh'95Z28conv is offline
Old 03-25-2008, 02:32 AM
  #19
Kaj
Kaj's Avatar
I can't believe your pushrod length. I wonder if you've figured it out yet? hmmm
Kaj is offline
Old 03-25-2008, 09:11 AM
  #20
black96z28's Avatar
Tying to figure out what to do yet, may end up changing, the Springs, PR's, cam and Timing chain..........
black96z28 is offline
Old 03-25-2008, 09:17 AM
  #21
dangalla's Avatar
now i understand why your having so many problems, you just dont listen
why ask for help if your not gonna listen. CHECK PUSHROD LENGTH
dangalla is offline
Old 03-25-2008, 09:26 AM
  #22
maverickmk's Avatar
and change one thing at a time, not a shotgun approach
maverickmk is offline
Old 03-25-2008, 09:40 AM
  #23
'94 Bad A Z28's Avatar
'94 Bad A Z28 is offline
Old 03-30-2008, 07:04 AM
  #24
black96z28's Avatar
There is other people haveing this same issue too, it seems all are pointing to the springs not having enough pressure..........
Old 03-30-2008, 07:44 AM
  #25
89385formula's Avatar
There are far more people running a similar setup without problems, then there are with problems. You don't seem to understand how or why pushrods that are too long cause these kind of problems. I don't see how you are running those pushrods, it doesn't add up to me. A had a previous engine builder measure pushrod length, and because he wasn't used to hydraulic roller setups his measurement was off .150". FWIW my LT1 required 7.150" pushrods with OEM lifters, and 7.250" with Morel lifters.
89385formula is offline
Old 03-30-2008, 10:19 AM
  #26
Yeahdoug's Avatar
Pushrods first, then springs. Never make two changes at once.
Yeahdoug is offline
Old 03-30-2008, 06:29 PM
  #27
The_Bishop's Avatar
Originally Posted by 94zgreenmachine
Like everyone else has said, check your pushrod length AGAIN, but if you are worried about spring pressure, just take the rear springs out of the back of your car and then maybe the pushrod length you have now would work.
Wait... What?
The_Bishop is offline
Old 03-30-2008, 06:35 PM
  #28
wrd1972's Avatar
Wa,Wa, What
wrd1972 is offline
Old 03-30-2008, 06:38 PM
  #29
MeanGreen97Z's Avatar
7.45" is entirely too long! 7.2" is stock. With a milled head, thinner head gaskets, and a decked block would take you to below 7.15".
MeanGreen97Z is offline
Old 03-30-2008, 06:45 PM
  #30
dangalla's Avatar
we have been telling him this for 2 threads and over a week yet he refuses to believe us because his "builder" says that cant be true
other than needing a new builder you need shorter pushrods, if your just to lazy to check them swap them for a set of 7.150 rods and take it for a ride and let us know how that goes
dangalla is offline
Quick Reply: by request new thread, hope this helps guys
