Reused old head bolts
Old 05-19-2007, 11:36 AM
  #31
arcticz28the383's Avatar
Personnally I would never use stock "torque to yield" head bolts over again. When you torque these bolts down, they stretch to achieve the necessary torque. If you use them again after they've already been stretched once, they tend to stretch even more which results in innacurate torque readings or even worse like one breaking down the road. I dont really care if people have reused them before, its not the way your supposed to do it.
The situation your in right now I understand, but I wouldnt trust old stock stretched out head bolts on your new build.
arcticz28the383 is offline
Old 05-19-2007, 12:08 PM
  #32
Z28LT1_Just_Nasty's Avatar
I have a tendency to replace parts strictly for piece of mind. Personally I replace bolts and parts even if they look perfectly fine. It's just one piece of the car I won't have to worry about down the line. The cost in time to do it is nothing compared to the cost in money it will take to repair a problem down the line. I know your money situation I'm in the same boat, but I'd kick myself in the *** from destroying things over a set of cheap bolts.
Z28LT1_Just_Nasty is offline
Old 06-26-2007, 01:29 PM
  #33
InSaneRed94Z's Avatar
whats another week of waiting for 50 bucks hell if you absolutely cant get 50 bucks, put your girl on the corner man, she'll make that 50 in a couple hours id hope
InSaneRed94Z is offline
Old 06-26-2007, 10:22 PM
  #34
JP95ZM6's Avatar
I vote for the crack them all loose in order to relieve stress, then replace one at a time, method. No different than re-torqing as far as the engine knows.
If you do get ARP bolts I'd recommend getting their lube and using the appropriate spec, too.
JP95ZM6 is offline
Old 06-26-2007, 10:44 PM
  #35
MeanGreen97Z's Avatar
I reused stock head bolts on 2 LT1s and put many miles on them without issue. These were higher mileage motors also.
MeanGreen97Z is offline
Old 06-27-2007, 01:33 PM
  #36
fireman's Avatar
I reused mine 4 years ago, you will be fine.
fireman is offline
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
maybe2fast
03-16-2015 09:45 AM
HectorM52
Parts Wanted
02-11-2015 09:33 AM
HectorM52
Parts Wanted
01-10-2015 09:01 PM
Quick Reply: Reused old head bolts
