rim and center bore ?
The problem is that the "early" 4th Gens had the rear axle hubs about 0.03" larger in diameter than the front hubs. I think they might have corrected the problem in 97 or 98. So if you try and put "late" wheels on an "early" 4th Gen, you may have to lightly sand or grind the inside diameter of the rear wheels to allow them to fit over the axle hubs. No big deal. Will not hurt anything, since the wheels are centered on the axle by the conical lug nuts, not the hubs. You might want to do the front wheels as well, so when you rotate the tires, you won't run into the same problem all over again.
