Rino Ramps
Old 02-17-2004, 03:40 PM
meangreen95z28's Avatar
Rino Ramps
Will these ramps fit under my 95 and 99? Any opinions from people that use/used them?
meangreen95z28 is offline
Old 02-17-2004, 03:42 PM
1msfyter's Avatar
Had mine for over 3 years always work great even on my owered Z. Had my truck on them also. Pep Boys $19.99 on special.
1msfyter is offline
Old 02-17-2004, 03:43 PM
atljar's Avatar
My car = lowered + ground effects.
Only takes a few 2x4 to get my car onto them. If no ground effects, should go on easily.
atljar is offline
Old 02-17-2004, 04:18 PM
JasonK94Z's Avatar
Is there any place else besides pep boys to buy these? Such as walmart, napa, ... No pep boys where I live.
JasonK94Z is offline
Old 02-17-2004, 04:26 PM
atljar's Avatar
walmart has them
atljar is offline
Old 02-17-2004, 05:05 PM
Aeromaks's Avatar
got mine for 20 bucks from pep boys, they are great, only thing is those rubber thingies on the bottom of them to prevent from slipping wears off in a bit.
but they get the car on fine, without any problems.
Aeromaks is offline
Old 02-17-2004, 05:06 PM
SlickBlack Z's Avatar
Autozone has them as well. They are great ramps...lightweight, wide and low enough for our cars.
SlickBlack Z is offline
Old 02-17-2004, 11:29 PM
fdxpilot's Avatar
I use on my 1" lowered 94 Z and a 02 Vette without any problems, although the plastic spoilers on the vette scrape a little going up. I understand a length of 2x8 in front of the ramps can cure that. For the price, they are excellent.
fdxpilot is offline
Old 02-17-2004, 11:32 PM
NewbieWar's Avatar
heh on my car (stock suspenssion) it drags but that rubber stuff keeps it from moving
NewbieWar is offline
Old 02-18-2004, 12:34 AM
camarokid24's Avatar
I second that ! I have a really hard time getting on them with the front wheels , one of them allways ends up jumping forward . Backing up them is easy. all in all they work great .
camarokid24 is offline
Old 02-18-2004, 03:42 AM
jkipp84's Avatar
A length of rope long enough to go past the rear tires will solve the ramp slippage problem. You just have to spend a little extra time lining things up before you drive up on them.
Just tie the rope through the hole in the center where you initially drive up on the ramp, then extend it out so that when the front tires are about to go up on the ramps, the rear tires are on the rope. That will anchor them when the front starts going up.
jkipp84 is offline
Old 02-18-2004, 07:40 AM
Coolformula's Avatar
got them from walmart for 20, there great i guess i wouldnt know my friends keeps borrowing them :P
Coolformula is offline
Old 02-18-2004, 08:56 AM
GREGG 97Z's Avatar
I've used them for years on my car, bought a set right after I got the car. They are nice and light weight and work pretty well. Except for the fact that people mentioned about them kicking out sometimes on a smooth garage floor when pulling up on them, that's a little annoying. That just got me thinking, I may add some additional rubber material to the bottom off them to stop them from kicking out, that little rubber pad just doesnt do it. I had just been using 2x4's in front of them up against the bottom of the wall to keep them in place but that doesnt always work. That's my only complaint with them.
GREGG 97Z is offline
Old 02-18-2004, 09:23 AM
Lower's Avatar
I'm amazed at how many people are exclaining how wonderful these ramps are, yet talking about how they slide out across the floor when you try to drive up them.
It just seems oxymoronic to say "These are great! But they don't work very well some of the time."
I have a set of the steel yellow ramps and a set of the low clearance wedges for them. It ran me about $35 for both sets of pieces at K-Mart.
They haven't moved once when going up or down them.
Lower is offline
Old 02-18-2004, 10:43 PM
Bud M's Avatar
I think the $30 rhino ramps at WalMart might have a higher weight rating. The $20 ramps are like 6000 lb capacity and I think I remember my Rhino ramps from WalMart being rated higher.
I like them because they are lighter than steel and easy to store and handle but they can slide on smooth concrete, same as steel. But what are these clearance wedges? Maybe they help the ramps not slide?
Bud M is offline
Quick Reply: Rino Ramps
